Will stock u-bolt's work with 2 inch lift blocks?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, Aug 13, 2001.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Will stock u-bolt\'s work with 2 inch lift blocks?
    I have a set of 2 inch lift blocks that should cure the Saggy butt of the 89 Blazer..
    My question .. will the stock u-bolt's work?
    Or my other option is to ad a helper spring.. which I also have.. will another spring in the spring pack give me a little more height til I can order a lift kit for this truck?
    Round Rock, Texas I haven't failed, I've found 10,000 ways that don't work. <a target="_blank" href=http://www.rocko.rockcrawler.com>www.rocko.rockcrawler.com</a>
  2. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Re: Will stock u-bolt\'s work with 2 inch lift blocks?
    The stock u-bolts are a maybe but I doubt it. I just looked at the u-bolts on mine and there is no way I could put a 2" block in there.
    I put a 2" or 3" (dont remember which) Trail Master add-a-leaf in my 4Runner to get rid of the saggy butt problem. They didnt even make the ride all that bad, I kinda figured that the stock springs were so worn out that the helper spring just brought it back to stock specs. I ran it that way till I parked it (for about 18 months). I dont see any reason why you couldnt do that till you got the lift.
    Scot in KC, MO.
    <a target="_blank" href=http://www.off-road.ws/images/users/Scooter/side_right_2.jpg>Blue 87 GMC Jimmy</a>
    Red 86 Toyota 4Runner (for sale $2000 obo)
  3. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Cool..Thanks Scooter.
    . guess I'll ad the helper springs.. or the new set of stock leaf springs I have here.
    I'll play around with it til it's right..
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Check the amount of threads showing above the nuts on the rear u-bolts. If there is at least 2" or more thread exposed above the nuts, you can use the 2" blocks. [​IMG]
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
  5. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks Wes..
    I'm going to use the leaf spring's I have in the garage.. counted the leaf packs.. the new set i have are 6 leaf.. the stock one's on the truck are 5.. should solve my saggy blazer butt problem.
    Wes.. the plates that go on top of the leaf springs.. I found one off a 3/4 ton chevy truck.. it was a 4x4.. will that work when I do my axle swap?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, those plates will work just fine!! [​IMG] Glad you found some because I dont have anymore except for some brand spanking new ones that I want to keep!
  7. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Well.. I only found one plate .. I have to go back and locate another.. or a few more.. [​IMG]
    I'm slowly trying to accumulate all part's necessary..
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hint: the 2wd plates are the same as the 4wd plates on all 3/4 tons. [​IMG]
  9. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks.. Hint greatly appreciated..
  10. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    I've always been told to absolutely never reuse old u-bolts.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You couldn't re-use the u-bolts if you wanted to anyway, it's nearly impossible to get them off without destroying them.
    Tim
