will the gears outa a 1980 14 ff fit a 92 k20 with 14ff?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MUDZILLA, Dec 24, 2001.
  1. MUDZILLA
    MUDZILLA Registered Member
    Aug 5, 2001
    16
    mo.
    i got a 92 k 20 housing 14 FF gears busted, i got this ole 80 model one ton i can pull the guts outa so do they fit? thanks in advance!!
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Should be a direct swap, but you will need to pay special attention when re-setting up the gears in the new housing to make sure htye are running the same tooth pattern and backlash etc etc...
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
