Will the rear axle from a 2wd 01 C1500 swap in a 99 Z71?
Discussion in '1992-Present Chevy & GMC models' started by afroman006, Jul 23, 2006.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    My friend destroyed the rear axle in his 99 Z71 and I am trying to locate an entirely new axle for him. I found one from a 01 C1500 2wd and am wondering if it will work? I know the new axle has 6 lugs and the brakes are the same, and the gears can be changed easy enough. Are the spring perches and shock mounts the same? Anything else I need to worry about? Thanks
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Check the WMS width. I'm not sure on the 99+ trucks, but on the 88-98 1/2 ton trucks the 4x4 rear is about 3" wider than the 2wd rear because of the positive offset wheels used with the IFS 4x4.
  3. afroman006
    Aug 21, 2002
    2,876
    Anyone know for sure?
