will the *trick u joint* give a uneven vibration?
Discussion in 'The Garage' started by uglychevyZZ4, Aug 5, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    didnt wanna waste a new post so im changing the topic of this one.
    will the *trick u joint* give a uneven vibration?????????
  2. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Re: Question on 1 Ton drivelines / yokes??
    anyone here, just take a stab /forums/images/icons/grin.gif
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You will need u joints. Put a new one at the t case and a conversion joint at the axle. The conversion joints are Napa Part # 447 and #342. I am not positive on the 342 number but you will need one or the other at the axle.
  4. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I guess I wasnt clear on my question, lol, i wanna avoid that cheater u joint and swap the yoke, but i dunno if there is one for my np205? and whats the part # ? and who has one, maybe even with a driveline? /forums/images/icons/grin.gif
  5. scooby
    scooby Registered Member
    Aug 26, 2001
    62
    SURREY B.C. CANADA
    take ur shafts to a driveline shop and tell them what u want and presto its done id up grade to 3/4 or 1 ton yokes on all my shfts ( i did) /forums/images/icons/smirk.gif
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i mean the yoke in the tranny, im trying to find a part number or what ever differientiates them 1 tons from 1/2 ton yokes.HENCE: so i dont have to buy one new, and can get one here on ck5 /forums/images/icons/wink.gif
  7. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    Im off to poke around in the junkyard this weekend for a one ton drive line. Im wondering what I can pull a yoke off of to acomplish this very thing. Its WAY cheaper to shorten a junk yard tube than it is to fab up new ones.
    Are the splined outputs the same on all 205"s? Is this one of those deals where I better take it apart and count the splines?
    A board member here offerd to sell me an adapter u joint.. And that may be a fine temperary fix... But I'm with you.. whats the point in leaving a weak link.
  8. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I was wondering the very same thing. what i really wanna figure out is if the d60 output shaft for the front /forums/images/icons/wink.gif will slide in the back so i can use that cv there? sheesh , im gonna have to start paying wess money for this, lol /forums/images/icons/grin.gif
  9. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    im also doing the conversion and need the answer to this one.do both driveshafts need to be changed for strength also or does just the rear need more strength?i still have the 1/2 ton d44 up front but will have the 14bff in the rear.thanx for any answers.
  10. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    you are fine, id suggest swapping the rear when time permits to a 1 ton, but for now your cool. the front is best to stay the same as the axle weight i think /forums/images/icons/laugh.gif til you get a D60.
  11. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Put the 1350 yoke on your transfer case.
    This is about $50 from gmpartdirect.com part number 6259081
    I got this info from Mike_Reeh.
    Now you can get your driveshaft as a 1 ton with 1350s on both ends and a thick walled 3 inch tube. Of course, this is going to co$t a bit more than just upgrading your current driveshaft with a 1350 on one end.
  12. BigMac
    May 27, 2002
    397
    Fremont, CA
    50 bucks ain too bad!
  13. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [/ QUOTE ]ok, now im really confused, i thought the 1350 was a u joint part #? /forums/images/icons/shocked.gif
  14. BigMac
    May 27, 2002
    397
    Fremont, CA
    he means a yoke that fits a 1350....
  15. dogman
    dogman 1/2 ton status
    Oct 31, 2001
    213
    California, Santa Clara Co.
    http://www.4xshaft.com/
    maybe you can get some answers here^
    <font color="orange">dogman </font color>
  16. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Sorry, I just told the driveline guy, I want to put a 1350 U-joint in the yoke. He said, OK. So I don't know how else to describe the larger 1 ton type yoke.
  17. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    EVERYONE: Thanks a bunch!
    DOGMAN: that link was the sheeee-ite /forums/images/icons/laugh.gif thanks.
  18. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    /forums/images/icons/shocked.gif Wholy canoly, look at this driveline that lets you flex up to 24" /forums/images/icons/shocked.gif [​IMG]
  19. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Does anyone run one of those drivelines?
  20. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Looks like a low-rider shaft or something. It's pretty narrow. I just went through the same thing. I must have called a dozen different driveline shops. Some told me one thing and some told me the exact opposite. Finally I had Arizona Drivelines make me up a rear high angle cv shaft all 1350 but it was pricey ($370). For the front they are just reworking my old 1/2 ton one, lengthening it and adding a high angle cv ($160). I wanted to convert the front to 1350 also, but it was more expensive because of the front yoke (around $400 total) so I decided to wait on it for now. Plus one shop told me something that seems to make sense. They said that the half ton front shaft has all the strength I'll need unless upgrading to a 1 ton front. Because of the gear reduction, the weak link in a front or rear end is usually beyond the gears. They said I'd break an axle joint or hub before the original 1/2 ton drive shaft ever breaks, even with stonger replacment axle shafts. Also, some of the heavy duty front shafts have fitment problems if you are running headers. Anyway, hope it helps.
