Will these A/C Brackets work on a DIESEL
Discussion in '1982-Present GM Diesel' started by AzzKicker, Sep 18, 2002.
  1. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I'm pretty sure the brackets won't work. Nothing swaps between the gasser engines and the diesels. The diesel engines are slightly larger than the small-blocks, and the bolt spacings are different. None of the other accessory (PS pump, alternator,) brackets are the same.
    The only thing common between the gas engines and the diesels are the motor mounts and the bellhousing bolt patterns.
    Casey
