Will these tires work for my truck?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Mar 13, 2003.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Will 33x12.50/15's tsl's fit on my 1985 stock rim? Also wil they fit without rubbing It is all stock with no lift? Since I live in CA now I only have been driving on the pavement so theres not allot of flexing going on. Rigth now I have 31x11.50/15's on it. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I have 33 TSLs on 15"x10" rims. The TSls are a "tall" 33" and are closer to 34". Interco recommends a 10" rim.
  4. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I put 33 X 12.50's on mine before I lifted the front and it rubbed even when driving on the street, this is with 15 X 10" rims.
    I then lifted it 2 1/2 inches, trimmed the front fender in the front and back and took of my sway bar. At Tierra del Sol I had a little rub in a few places where I was all flexed out but nothing that would damage tires or sheet metal.
  5. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok what if the read is only 50% left? Will that affeect any rubbing?
  6. dyeager535
    26,976
    You'd probably need to lose more tread than that to keep from rubbing. Go with narrow but tall tires, lift, cut, or face the consequences.
  7. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Well I cant lift it yet cause I dont have the front srpings and brake lines yet. And Im jobless. So it looks like Ill just look for a different tire to put on the truck.
  8. dyeager535
    26,976
    32x11.5's cleared on my last truck ('83 w/stock rally wheels, 2 leaf front springs) but there are still a lot of variables to work around. They might be an option for you.
    If you need tires bad, and not just for looks, it never hurts to check around with the used tire places. I've gone that route in the past...not much tread left usually, but enough to be legal, and a LOT less than new.
