Will they fit and how would they look? Take off wheels from 2001-03 2500's
Discussion in 'The Garage' started by BigOrange90Jimmy, Apr 14, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Will they fit and how would they look? Take off wheels from 2001-03 2500\'s
    I'm sure it's been asked before, but I can't find anything on it.
    I'm converting my 87 K5 to 3/4 ton and was considering running the chrome wheels from a 2001-present 2500. The lug patterns are the same, are they not? Would the backspacing on them kill it? Would they clear the tie rod and everything?
    Thanks!
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Re: Will they fit and how would they look? Take off wheels from 2001-03 2500\'s
    im pretty sure they are a metric bolt pattern, and yours is a standard pattern, so no they will not "bolt on"
  3. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    hmm...i wonder how Petersen's got them to work on that suburban they were building? guess i need to break out the magazine collection and start searching.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I'm not so sure about that. As far as I know, only the new Superduty Fords messed with the lug pattern. GM's should still be the 8 lug on 6.5" pattern. (The new superduty's are 8 lug on 170mm) Someone correct me if I'm wrong.
    As far as backspacing...I'm not sure (but would like to know)...so someone who has that measurement speak up. /forums/images/graemlins/thumb.gif /forums/images/graemlins/ears.gif
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The bolt pattern is a standard 8 lug. Metric is only a Ford ****-up AFAIK...
  6. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    I thought so because they used a 1st gen 14b in that suburban they built.
  7. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    ahhhh, i see says the blind man to the deaf dog.
  8. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    They will bolt right on, and the backspacing is correct, but they are only a 6 1/2" wide wheel. Also, the center caps will require some work to be compatible with your front lockouts.
  10. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    I just put a set on my truck to try and get rid of DW.The front went on no problem,but the back wont fit over my Dana70 axle flange.There the aluminum ones.Oh yeah no more DW with them on the front.
  11. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Who needs center caps? /forums/images/graemlins/rotfl.gif
