Will they fits
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by porkchop, May 17, 2002.
  1. porkchop
    porkchop Registered Member
    Apr 29, 2002
    21
    NH,seacoast
    Who in this wonderful place can tell me if 32x12.50 will fit on the factory rally wheels ? (6 lug) And if they do can I still run my factory setup for suspension? It does'nt sag in the front at all and if there was a fit problem could I get away with a AD a leaf for front and rears. Thanks for any help
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I ran 32x11.50's on factory rally wheels for a long time before the lift went in. It worked great. I don't remember ever rubbing, and if I did it was very minor.
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I put 35x12.5s on my factory wheels. I also had a 4" lift.
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    i ran 32x11.50s on factory rally wheels for a while no problems. I had rubbing problems when cornering when I put them on 15x10s. but i also had spring sag in the front. you should be cool.
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i am running 38x13x16 swampers on a set of stock 16x6.5in steel rims /forums/images/icons/smile.gif
  6. blazentank
    blazentank 1/2 ton status
    Apr 18, 2001
    426
    Houston, Texas
    do you want to buy two 32's that are used they still have about 70% tread
  7. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    also ran 32x11.5's on factory 8"wide ralleys with no lift. looked and worked great.
  8. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    i have 33 12.50's on a none lifted
  9. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    You CAN, but it could rub a bit. I had a 2.5 inch lift with 32's (11.50's though, on a 10 inch wide rim) and they rubbed a tad off-road. What brand is the 32 12.50? With the narrow wheels and normal 32's I've seen trucks run with stock suspensions, but if you get it flexing you'll probably rub a bit.
  10. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I have 33x12.5's on stock wheels, no rubbin, except on sharp turns at speed(the suspension compresses). Otherwise, no rubbin. tried to stuff it too, no rubbin (yet, im sure this is just a fluke)
