Will this 14 bolt work?
Discussion in 'The Garage' started by camokrawler, May 10, 2006.
  1. camokrawler
    camokrawler Registered Member
    Mar 2, 2006
    47
    Central North Carolina
    i have an 87 chevy 1/2 and found a 14 bolt ff for 150 out of a 79 van, will this fit my truck? i know i would have to move the spring perches.
    thanks
    camokrawler
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    yeah after you move the spring perches it will work. its wider too so itll give you a nice stance.:D
  3. camokrawler
    Mar 2, 2006
    47
    what makes it wider the hubs? are all the upgraded shafts the same for all 14 bolts?
  4. 79k20350
    Nov 22, 2004
    7,757
    Ct
    i think its just the hubs but im not sure if the shafts are the same or not.
  5. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    why do you need upgraded shafts? have you ever even heard of someone breaking one? i happen to have a spare set that i got for free. i think they will make good pry bars.:D
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    no it wont work at all
    ill trade you it for the 14ff in my blazer right now
    minus gears and locker of course
  7. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Lucky, I think the shafts are different too. That is from the pickup
  8. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    I just started axle project. I have 14ff from Van, and when I bought it, I measured it to be about 6 and ½ inches wider than 12-bolt. Relocated spring perches, custom 15" wheels and it should work fine. Just a week ago I shaved 2" off from the pumpkin :D Need to fill the hole and mill off 1/6" off from the ring gear.
  9. REDCRO_REDNECK
    REDCRO_REDNECK 1/2 ton status
    Apr 7, 2005
    241
    mo
    I have a 14 bolt from a van also. does anyone know if the disk brake kits will work on it too?
  10. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    so if my step side needs something a little wider than i have right now i could just get the 14b out of a van and it would push the wheels out a little more?
  11. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Van 14ff axle is 3" wider than a truck 14ff and the axles are longer as well. Yes the rear disc conversion will work on the van axle.
