Will this 205 bolt in to my TH400?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Apr 5, 2003.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    My TH400 is mated to a 208 case, will a 205 from another TH400 bolt up to mine with no problems? Or is there some gismo I have to get to make it work?
  2. DrMaserati
    DrMaserati Registered Member
    Apr 5, 2003
    23
    Oregon
    It probably will. The TH400/NP205 was a standard combo about the early 80s. But you will lose the exceptional low range of the 208. A 208 has a low range of 2.61:1, while the 205 has a low range of 1.96:1.
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Isn't the output shaft from the 400/208, trans longer than the 400/205 trans? I thought it was. I have heard of people cutting them down, Just thought that was the only difference.
  4. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    That's what worries me. The output shaft being longer. I thought maybe I'd have to swap it out, but if I can just cut it then that's what I will do. Unless swapping the output shaft is not too expensive or time consuming.. /forums/images/graemlins/confused.gif What would you do?
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, a 205 will mate to your 208-version 400, ONLY IF, the 205 is the round 6 bolt pattern t-case found in the '85-'91 K and V30's.
    The '84 and older figure 8 pattern 205's will not fit to the 208-version 400 as the output shaft is longer on the '84 and older 205-equipped 400's.
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    So, is the shaft stickout from the transmission the only problem and can it be cut shorter?
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Not if the 400 had a 208 behind it. Just find the '85-'91 np205 and bolt it right onto the 400 with the proper adaptor and you are done.
    Now if you had an '84 or older 400/205 combo, then you may need to shorten the shaft but I highly recommend you NOT to cut the output shaft of anything. Locating the proper length shaft is the preferred method.
  8. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    The transfer case is out of an 89. Do I use the adapter from the 400/205 or will the 400/208 adapter work?
  9. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Wes? /forums/images/graemlins/confused.gif Anybody?
