will this axle fit
Discussion in 'The Garage' started by scrappyk5, Feb 19, 2003.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    just checking to see if a 14bff from a 74 c20 will
    fit under my 84 k5 blazer . thanks .
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Should fit no problem. Just have to deal with the u-bolts and u-joint. </font>
  3. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    is that fit including the e-brake ?
    thanks
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    no ebrake, atleast mine didnt match up, i still havent delt with it, dont really know how hehe,
  5. One_Ton_k5
    One_Ton_k5 1/2 ton status
    Jan 30, 2003
    168
    St Paul Minnesota USA
    Will the stock driveshaft work if the truck has no lift?
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The 14 bolt uses a 1350 ujoint.
    Your drivehshast will have a 1310 ujoint.
    What some people do is buy a conversion ujoitn from NAPA with 1310 caps on one side and 1350 caps on the other.
    Try a search for more info on this.
    -- Mike
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    My driveshaft fit, but i had it shortend,it was about a 1/4 inch from being fully compressed. i pictured jumping my truck, and when landing, my driveshaft having no where to go, and causing some DMG,
  8. One_Ton_k5
    Jan 30, 2003
    168
    Uh yea, that would suck. If you don't mind me asking, how much does it cost to have a shaft shortened? Or can you do it yourself?
  9. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Its prolly possible to do it yourself, but i wouldnt. I had 1350 Yokes put on both ends of my rear shaft, rebuilt yoke, new tube, Basically a new one ton driveshaft made to the lenght i need for 300 bucks also i gave him my old driveshaft.
  10. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    well i have a 4" lift, so the driveshaft should be ok.
    i will go with conversion u joint , but i needed to see
    if the e-brake will work.
  11. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    we just put a 60 front, in my friends with a 6 inch lift, his driveshaft was never lengthend for the 6 inch lift, so we figured the 60 would shorten the driveshaft for us cuz of the longer pinion, the front shaft needed to be shortend to even bolt up..... You might be ok, i dunno,
