Will this cam work ?
Discussion in 'The Garage' started by njonl, Sep 19, 2005.
  1. njonl
    njonl 1/2 ton status
    Jun 30, 2003
    128
    Northern CA
    Whats up guys,
    I have an '89 Blazer with a stock TBI 350. A buddy of mine just bought a ZZ4 crate motor and he already swapped out the cam and he was going to throw the stock cam away. I said I would take it hoping I would be able to use it in something maybe. My question is, will this ZZ4 cam work in my stock motor ? What would I need to do to make it work ? Would this even be worth doing ? Thanks for any input anybody might have.
    -Nick
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    for an 89 motor, you should have roller provisions just not equipment. If you want you can get the rest of the parts, and it would be a strong motor with the cam, but i dont know what you would have to do about the tbi computer.
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    running a .510 lift cam on stock heads isn't doable. waste of time and money even if you could run it the stock PROM wouldn't be happy and it would probably run like a samari.
    You could run that cam but you'd have to swap out the valve springs which is a giant waste of time and money.
    check out crane cams powermax cams...
    easy 20 hp without touching the computer.
