Will this fan do the job?
Discussion in 'The Garage' started by vdubbin86, Jul 21, 2004.
  1. vdubbin86
    vdubbin86 Registered Member
    May 25, 2002
    55
    Alberta, Canada
    I have a Black Magic 150 layong around from a previous project and I was just wondering would it do the job in the Jimmy.
    Specs:
    Mounting Surface Required - 18" x 16" x 4 1/4"
    Fan Diameter - 15"
    Number of Blades/Fan Blade Angle - 8/26°
    Fan RPM @13.5VDC - 2200
    Airflow-Cu. Ft./Min. at 0º Static Pressure - 2800
    Adjustable Thermostat 180º-240º - Yes
    Air Conditioning Relay - Yes
    Link: http://www.flex-a-lite.com/auto/html/black-magic.html
    Opinions?
    Thanks.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    How big of a radiator? What kind of weather in your area? I have the flex a lite dual 13.5" fans that pull 4600 CFM. They pull a lot of air but I don't have plenty to spare, I have a built 406 and a 4 core rad.
    I would try the black majic and if its not enough than add a little 10" fan out in front, that should be plenty to keep a stock 350 cool.
