Will this fit a chevy 3/4 ton D44?
Discussion in 'The Garage' started by bayou blazer, Sep 29, 2005.
  1. bayou blazer
    bayou blazer 1/2 ton status
    Jul 16, 2004
    176
    la
    Ford D44 hubs
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I looked up the bearing part numbers for an '85 Ford F250 and an '85 Chevy K20 and they were exact matches. I don't know if the inner and outer bearings are spaced the same distance apart though; one brand spindle may be longer than the other brand.
  3. bayou blazer
    Jul 16, 2004
    176
    la
    thanks for the info
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    ford is the odd ball. gm/dodge swap easy.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Why pay that much for them when you can get them cheaper? I wouldn't waste time with Ford parts when you can get the correct GM stuff instead.
    Another thing I believe won't allow the fitment of the Ford rotors on GM's: hat depth of the rotors. Even though the bearing hubs may be the same or fit the same, the hat depth of each can be different in where it won't allow the proper fitment of the calipers since it would either put the rotor too far out or too close in to the caliper mounts.
    If you are really bored, go to your local parts store and have them pull bare rotors out and measure them to check the differences.
  6. sweetk30
    Nov 1, 2004
    25,537
    536
    yes that is true on rotors. gm 3/4 8 lug is one distence from back to stud area. the ford ones are 1/2" more to the same area.
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I am pretty sure the rotor contact area is farther out. They won't work easy. You can get chevys from a local part store for less.
  8. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    a freind of mine has a SFA in his newer Z71 its a Ford 44 and has chevy 6Lug hubs on it but he may have changed the spindles IDK I would just buy some Chevrolet hubs check NAPA
