will this fit my 6.2????
Discussion in '1982-Present GM Diesel' started by 4x4dreamer, Oct 31, 2002.
  1. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    6.5 intake Will it flow more than my non Jcode intake?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I believe both share the same overall dimensions, since I have seen a rebuild starting with 93 6.2 punched out to 6.5 and used all 6.5 accessories and Turbo.
  3. 6 2 Carl
    6 2 Carl Newbie
    Nov 2, 2001
    4
    It will bolt up to the heads, but you won't be able to use your round air cleaner, without some modifications, since this intake has a hexagonal shape to it. You will also have to adapt your CDR lines to fit this intake.
    I would recommend waiting for a 6.2 J intake that came off of the same body style as your truck (82-87) , it will be a direct bolt on.
    Carl
  4. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    Awesome!! Thank you!
    Now, I just have to scrounge up 80 bucks to get a Jcode....
  5. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Carl is correct, it will bolt right up, but your air cleaner won't fit. It's designed to bolt to the pressure housing coming from the turbo on the 6.5L setup.
    You'd be better off with a J code intake from an 88-92 6.2L.
    Casey
