Will this Shackle work for a shackle flip? (pic)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Taylor, Sep 13, 2002.
  1. Taylor
    Taylor 1/2 ton status
    Jul 17, 2002
    326
    Elizabeth, CO
    I bought a shackle filp from Echobit to replace my rear blocks, and after looking at some of the phots of other peoples shackle's I'm not sure if mine will work, because it seams to be a totaly different style. Can someone give me some advice on this one. Thanks
    Here is a photo: Shackle photo
  2. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    What is that thing!? It looks like it is supposed to limit spring movement. Does your rear end currently sit low? I don't think it will work.
    You may be able to use the upper part of it for a shackle but I'm not sure it is long enough. I'd get some shackles from a junk yard or from a 4 wheel parts supply store, maybe even NAPA.
  3. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    You have the pivoting aftermarket shackles that are supposed to improve ride quality. The problem is that they are designed to work under tension, and the shackle flip is a compression design. So the ones you have aren't going to work. Find someone to sell them to and get you a set of factory shackles.
    Mike
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'd like to see the shackle, but imagestation isn't allowing me to look. /forums/images/icons/frown.gif
  5. Taylor
    Jul 17, 2002
    326
    Elizabeth, CO
    I updated the link, it should work now.
  6. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Ah yes, they wont work for the above reasons.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Those are "Velvet Rides" and no, they won't work in compression as others stated...
