Will this wheel fit?
Discussion in 'The Garage' started by 78Suburban, Oct 31, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Will this wheel fit on my 14bff and front 10 bolt? Basically, I'm wanting to know how big the 14ff hubs are. Also, what does a reverse backspace wheel mean?
    http://store.summitracing.com/
    type in part # USW-75-5880R
  2. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Didn't actually look at 'em but if they're 4.25" of backspacing or less than they'll fit on the 14 bolt drums. Even if they're a little more than than you can take a little bit off of the fins on the brake drums to make them fit. You might have to grind your front calipers a tad but I don't know that for sure.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    they are 2.5"bs i dont see a problem with them fitting
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    what I'm wondering about is the hole diameter... will the 14ff hubs clear? I'm window shopping for Christmas :xmas:
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I *THINK* most 8 luggers are bored large enough to clear Ford D60 hubs, which would give you plenty of clearance.
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    2.5" backspacing, they will bolt up with no problem. i have 2.75" backspacing and the big 13" drums in teh back and they clear no problem, the front is the same way clear with no problem.
    the center hole should fit the 14bff hubs with no problem.
    the reverse center means that the drop center for putting tires on the rims is on the inside of the wheel instead of the outside like a normall center wheel. it makes it harder to loose an outter bead when aired down.
  8. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    :grind: :grind: is not needed
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Now if they weren't CHROME, I would have it made :D ....... how wide of a tire could be run on 8" wheels?
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I'm disappointed in the chrome but we all need a little bling :p:
    You can cram whatever tire you want on an 8" rim. People have run 44" TSL's on them before.
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yup ive seen 44s on 8" rim, jus makes it balloon and prolly wear funny but thats a 18" wide tire
  12. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    a guy at church has a way to powdercoat things.. Is it ok to powdercoat chrome??
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    It'd have to be stripped, just buy an unpainted rim.
  14. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    this is the only one with 2.5" backspacing... I would rather an unpainted or black, but that is all summit carries :eek1:
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Any particular reason you don't want more backspacing?
    If you're fond of those particular dimensions, PM BlackMesaOffroad or look up Timmay (don't flame me, he found the exact rims I wanted but couldn't find).
  16. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
  17. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
  18. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I wonder, how do I know what the maximum weight load for that wheel is? Is it really critical? Is the tire load range really critical? because my burb is like the TITANIC :burb: :yikes:
    thanks,
    James
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    they are steel, i dont think ull really have to worry bout load
