will this work for 8lug swap?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, Apr 23, 2001.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    ill be swapping eevrything from spindles out from a 76 3/4 dana44 onto my 74 1/2 d44. everything will work right? even my stock calipers? im pretty sure i have to change spindles though.....
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Everything should work... Double check the spindles beside each other.. Also, check the 74 and see if the shafts have the 297-x u-joints. If not, use the 76 shafts...... 74 was the first year for the 297's, but you never know with GM....
    Other than that, sounds good to me!
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
