will this work
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zenlh, Feb 26, 2005.
  1. zenlh
    zenlh Registered Member
    Aug 12, 2003
    35
    tuba city, arizona
    i have a rebuilt 85 350 with the four bolts that hold the valve cover down on the outside i believe it's call standard heads. i have a 87 chevy with a tired 350 with center bolts on the valve covers and tbi. can i switch heads on the 85 350 to center bolt heads and drop it into my 87 with tbi and make everything fit with out any problems or are the blocks different? thanks in advance
  2. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    I dont know of any reasons why you would have to change the heads. I thought the only difference were the later Vortecs. You should be able to just switch the intake manifolds for the TBI. Engine sensors, Im not sure about. 85s had carbs.
    Please correct me if Im wrong.
  3. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    the center 4 holes need to be angled to fit tbi intake to old style heads. other than that go for it. but use the 85 flywheel or flex plate. there is old and new style from when thay went to 1 peice rear main seal.
  4. zenlh
    Aug 12, 2003
    35
    tuba city, arizona
    when you say angle the 4 holes, do you mean to make the holes in the manifold bigger. thanks for the heads up on the flex plate.
  5. sweetk30
    Nov 1, 2004
    25,552
    545
    if i remember correctly the old angle was 90 degress and the tbi angle is 72 degress? but i havent done this before . lots of people have and i have seen it work. thay just use a die grinder or round file and open the holes the way thay need. just remove the intakes and look at both you will see the differance.
  6. zenlh
    Aug 12, 2003
    35
    tuba city, arizona
    it'll work
    :laugh: thanks for all the help researched on internet, and found that all i need to do is exactly what you said. i will go on with the engine replacement after i pick up a new flex plate.
