will this work?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by arq, Apr 25, 2001.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I'm trying to get about a 1" lift in the front of my blazer. I have an extra set of leafs that i am thinking of sandwitching in the spring pack. currently i have 3 leafs, i'd end up with 4 leafs in front. I know that i would have to change the center pin. I thought about the ORD 1"addaleaf, but if i can get similar results with the extra leaf i'd only have to spend on the center pin and u-bolts. Any draw backs on doing this??
    thanks,
    ARQ.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    as long as the center pin keeps the posiablity of spitting out the added leaf. Sould be oK, just re torque the Ubolts after a few mile to make sure.......
    .02c
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. 72GMCJIMMY
    72GMCJIMMY 1/2 ton status
    Mar 17, 2001
    142
    I did it to a 65 J-series Jeep pickup, and a FC 170 Jeep pickup I owned. The FC170, I did it to handle the extra weight of the small block Chevy I put in it. It worked out well for me. I Used a number eight center bolt, and if you are adding a long leaf you will have to modify your spring clamps. As far as the U-bolts, maybe they will be long to have a few threads showing after you tighten them. The only draw back might be the ride, but maybe not.
  4. travis
    travis 1/2 ton status
    Nov 17, 2000
    173
    Panama City, FL
    Another option you can consider is the 2" longer than stock shackled offered by <A target="_blank" HREF=http://www.hill4wheeldrive.com>http://www.hill4wheeldrive.com</A>. I'm not sure of the part # but I think they cost around $69 plus you still have to supply your own bushings. The 2" shackles will actually only lift the front by about 1". I know you don't want to spend the money but it's only a suggestion. Just my 2 cents you can add to your bank.
    Travis
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    I think i'm gonna go for it. I just got a get another spring clamp that will hold the extra leaf and the center pin.
    thank you,
    ARQ.
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Dennis, I'm not sure that adding a leaf will get you 1" of lift. It will definitely make the Blazer ride more harshly.
    Before I put the blocks in the back of my Blazer to get rid of the tail-low attitude, I spoke with a sring shop in Oakland that would re-arch my springs, and was going to have them do it, but I found the blocks for real cheap and didn't get the springs re-arched. Perhaps this would be the way to go if you don't like the ride quality that the added leaf gives you.
