will wheels off of an IFS truck fit solid axle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Calclips, Jun 20, 2002.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Will a set of wheels off of an IFS truck fit on a solid-axle truck? If somebody can post the picture in a post for me I can supply one.
  2. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    if same bolt pattern, yes.
  3. Calclips
    Apr 4, 2001
    1,005
    the IFS truck is a 1990 GMC 1/2 ton pickup, is the hollow area in the center of the wheel where the centercap goes going to be big enough for a manual locking hub to fit through?
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    The factory steel wheels off my 1992 Chevy 3/4 ton 4x4 (6 lug) would not fit over the hubs on the factory 10 bolts on my K5, even though they had the same bolt pattern. (It has been a while since I've had 10 bolts) /forums/images/icons/cool.gif
  5. Calclips
    Apr 4, 2001
    1,005
    The wheels that I'm talking about are aftermarket... so they just may fit. I think I'm gonna go outside and measure my openings, and then measure a co-worker's hubs.
  6. little79k5
    Mar 27, 2002
    230
    panama city, fl
    ahhhh, forgot about that
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    While your at it, you may want to check the back-spacing as well...
  8. Calclips
    Apr 4, 2001
    1,005
    how do I do that? I know that the aftermarket wheels have stick out of the fenderwells of my GMC about 1.5-2" with 33x12.5's on them.
  9. Calclips
    Apr 4, 2001
    1,005
    I think the wheels that I have will fit a solid axle. The centercaps are bigger arround than the visible part of the manual hub, leading me to believe that they will fit.
  10. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    I don't know if the IFS wheels are supposed to have more backspacing, but they sure look like they have a wider track width. That's why an average set of 15x10's will stick out about an inch beyond a k5 fender, but so many IFS trucks have the same wheels sticking way out. Just look at a stock K5 and a stock IFS truck. The older trucks have the tires way back in there under the fenders. Is this track width or fender width? /forums/images/icons/confused.gif
  11. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    If you are running 8 lug wheels then yes they will. I installed a set of chrome/stainless wheels off of a late model HD onto my 1988 1 ton crew cab with dana 60 front. No wheel spacers were required.
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'm pretty sure that stock 6-lug IFS wheels won't fit on a solid axle. The offset is too deep. The inner bead area of the wheel hits the tie rod ends. With aftermarket wheels, it's a toss up. I've seen some aftermarket wheels mounted on IFS trucks that obviously have the incorrect offset for IFS. The wheels/tires end up sticking way out past the fenders. Those wheels may indeed fit a solid axle. You'll just need to bolt one up and see... Test the front first. That's where you're most likely to run into problems.
  13. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Solid axle trucks have 3 1/2" backspacing stock. IFS trucks have 5 1/2".
