Will wheels work with stock K5 Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JC50, Mar 13, 2002.
  1. JC50
    JC50 Registered Member
    Mar 13, 2002
    11
    Florida, U.S.A.
    I currently have an 87' K5 Blazer w/ original 15 x 8 wheels that I've been running 33 x 12.50 x 15 tires with no problems whatsoever. I'm thinking about getting bfg a/t k/o's same size but install on an American Eagle wheel 15 x 10 w/3.62" back spacing. I have no lift, just stock suspension. Would I be ok with this set up? Any info appreciated.
  2. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Not sure what the back spacing is on the factory wheels, but you should start there. Measure what you current wheel back spacing is and see for yourself if you new wheels will fit.
    ...... Welcome aboard....
  3. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    You will probably rub when you turn the wheels, or if you flex the suspension much.
    But the good news is now you have a great excuse to lift your K5.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have an 89.
    I'm running 33s on 9" US wheels with 3 1/2 " back spacing with no lift. I had to cut a small piece out of the back inside on the fender wells on the front. It rubbed a little when I flexed real hard. But have had no other problems.
