Will yoke from 203 fit 205 and are any parts interchangable?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, Nov 21, 2001.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    just what it says, I am converting my slip yoke TH400/205 to fixed, I just don't have a 1350 yoke I only have the one that came on the other tcase I am disecting. Also I heard a rumor that the parts from a 203 can be used to make a 205 fixed yoke? Can anyone confirm this?
    Thanks for any help,
    Mike
    The jeep eater ......jeep it's what's for dinner&lt;img src="http://coloradok5.com/forums/images/icons/crazy.gif"&gt;<P ID="edit"><FONT class="small">Edited by mpascino on 11/22/01 12:06 AM.</FONT></P>
  2. mpascino
    Jan 1, 2001
    557
    Connecticut
    ttt
    The jeep eater ......jeep it's what's for dinner[​IMG]
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    According to a Spicer book that I have, the 1/2 ton NP203, rear output yoke, and the 1/2 ton NP205, rear output
    yoke are the same part #. But I beleive it is a misprint/mistake.
    Anyone have provf ?
  4. mpascino
    Jan 1, 2001
    557
    Connecticut
    I have had someone else tell me the numbers ar the same, but still no part numbers.....I'll keep looking.
    Thanks,
  5. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    The rears of both have the same spline count, it should fit, although a different seal maybe needed.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    I checked my Dynatrac catalog and they show the rear output yokes on the 203 and 205 to be EXACTLY the same. Same part number to be swappable between the two.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  7. mpascino
    Jan 1, 2001
    557
    Connecticut
    thanks for the info
  8. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Wish I was back in town earlier, but to answer the question, yes they are both the same. Only the yoke can be used to convert a slip yoke to a fixed yoke. Converted a TH350/NP203 to 700R4/NP205 earlier this year. Had to get the output shaft from 4X Heaven, and the output bearing retainer (the output shaft cover) from Blumenthals here in OKC. Get a good set of split ring pliers and a set of end play washers to set the end play to 0.002 to 0.027" or you'll eat the output shaft bearings up and have a vibration problem that will kick your butt and drive you to the brink of going crazy (been there, done that...). I just put a Ph**d out put yoke to mate up to the larger CV joint on my new drive shaft (I now have a spare yoke which new cost me $25 about 2 months ago while chasing down said vibration problem).
  9. mpascino
    Jan 1, 2001
    557
    Connecticut
    are you interested in selling the yoke you have? Do you know what u-joint it is for? Thanks for the help, I am trying to get a game plan together. Also are there any parts of sorts you are looking for?
    Thanks,
    Mike
