Will zero rates work?
Discussion in 'OffRoad Design' started by JF 89K5, May 17, 2002.
  1. JF 89K5
    JF 89K5 Registered Member
    Mar 13, 2000
    68
    Shoshone, Idaho
    I did a search and could not find an answer to this ? So here it is, will zero rates work on the rear (duh) of my 94 suburban (8 lug)?
    Thanks,
    JF
  2. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Does it use leaf springs? Are those springs on top of the axle? If you answered yes to both of these questions, then yes they will work.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    They should work fine, make sure you have enough ubolt length and you're good to go. The only place to be prepared for some variation is the center pin size but that will be minor variation at the most.
