Willys pickup tech
Discussion in 'The Garage' started by b454rat, Jan 3, 2007.
  1. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I can get a Willys pickup for dirt cheap. Thought about taking all the running gear out of the 89 and putting it in the Willys. But did some searching, and I think with full width axles and 40" boggers would put the tires clear past the body. I can't find any "hardcore" trucks out there done with full width, tires,etc. Can't even find what the stock WMS on the stupid things.
  2. willymonster
    willymonster 1/2 ton status
    Feb 18, 2006
    183
    PARADISE,CA
    do the willys!!! i put rockwells and 49 inch iroks under mine . although i guess your right the tires dont really fit under the :D but if you were concerned with fender coverage i think a waggy front axle would fit nicely. you can get one at picknpull for about 130.oo bucks .
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I used to have a '56 P'up. Front & rear are different WMS's.
    According to Ackerson's "Standard Catalog of 4x4's; 1945-1993" (ISBN 0-87341-203-6) the front tread width is 56in and the rear is 63.5in from 1947 thru 1965
    Those frames are really marginal for any re-power project. I see a fair number of those bodies swapped onto other chassis.
  4. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
  5. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    if you're that concerned I'll buy the willy's from you then you won't have to worry about it. I've been looking for a willy's to use for ever!!:bow:
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Dang man thats what I am doing right now helping a freind build a 52 wagon.
    About the frame, I hate to say this but they fit pretty darn good on a 78-79 bronco frame. I don't like the way they sit on a chevy frame.
    On the project I am working on we are just beefing the stock frame boxing in the whole front area adding crossmembers and the such, we also extended the frame up front a little to allow the use of some springs I had laying around. If we would have been able to work on it tonight I we might have had the springs on and an axle underneath it. Oh well hopefully next week.
    We are using 3/4 ton axles. Keep in touch I will let you know how everything goes.
