Willys Wagon on K5 chassis
Discussion in 'The Garage' started by samiam, Feb 9, 2004.
  1. samiam
    samiam Registered Member
    May 17, 2003
    42
    My 73 K5 body is almost spent, too many close encounters with non-forgiving rocks. The Krylon just didn't protect like advertised. Have a 62 Willys Overland ( 2 door station wagon basicly) that would look really sweet on the K5 frame. Has anyone done this ? Let me know.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    doh his name is slipping my mind at the second but there is a member here that did just this. He has 57" front springs on it.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Jeremy, aka 55willy /forums/images/graemlins/thumb.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yep now I remember, ha
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    my webshot folder
    I also have some in the member area, which I can't link ya too since I'm Blu:(.
    there is also a page of it on Mandy's web site that showsthe first couple stages of the build up.
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Here is a bunch more of Jeremy's when I helped him put the 55 willy's body on the K5 frame /forums/images/graemlins/waytogo.gif
  7. samiam
    May 17, 2003
    42
    Thanks I checked the site and it looks really cool
  8. samiam
    May 17, 2003
    42
  9. samiam
    May 17, 2003
    42
    I am sure to have ? after ? . Here is thanking you in advance . Im lucky that my Doner body is in really good shape, no rust, not even speaker cut outs. Will be in touch, be thinking of what I can barter for info.
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I hae helped a few through emails who have done or are doing the same swap. It's easier then most body swaps since the basic measurements are pretty close.
    if you ever need more info you can enter 1955 willy's or 55 willy's or willy's wagon in any search engine and I'm normaly within the top 5 matches,LOL.
    The one thing I will point out is you need to move the motor back in the frame or put the radiator in the back. Or I guess you could cut out the rear wheel openings and position the body farther forward.
  11. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    Muddytazz, I would really like to view your album, but it is telling me that the album is password protected. Please advise.
  12. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Did you join Imagestation? You have to join to view the pictures.
  13. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm also a member of imagestation and yes it is password protected. I forgot the passwrod so I started guessing, I think it ended up being "55willy" or 55 willy" I forgot again, LOL
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    DwarF, you should be able to view them now. I also forgot that is was passworded, so I removed it /forums/images/graemlins/thumb.gif
  15. G.M.H
    G.M.H Registered Member
    Oct 6, 2002
    78
    wpg. mb canada
    I have a 54 pickup body on a 1980 frame.I moved the engine back exactly 4 inches if I recall.I also had to shorten the box by 12".I have added a doubler and there is still enough length for a driveshaft.Cooling can be a problem as there is not enough frontal area available.I have a plymouth fury rad which was recored to 3 row high efficiency, and it is not quite adequate.With mine frame flex/fatigue is a problem, as the chevy one piece body added a lot of stiffness to the frame.On a wagon this may not be an issue,but use as many body mounts as possible.Good luck with your project.
