WinALDL....UPDATE: new question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by heavy4x4, May 12, 2004.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, I'm getting a laptop ( /forums/images/graemlins/woot.gif), so now I'll be able to check out what my computer is getting from the sensors using the WinALDL software from here.
    I have a couple of questions though for those that have used it. I'm sure I'll learn how to use the program as I go, but my main question is in building the cord. It gives several configurations (with and without certain resistors) and I'd like to know which configuration you used that will also work for my '90 burb. And, did you build the cord using items that can all be found at RadioShack or a CompUsa store? (I have the ability and know-how to do this but want to know where you got the parts from)
    And finally...for the numerous numerous readings this program will give me. What should I be looking for? Again, this is probably a learn-as-you go thing, but any help would be great. I've got all the service manuals for my truck. Should I be able to compare all the values this program spits out at me with the values buried somewhere in these books?
    Thanks for your help. I can't wait until I can play "auto technician." No more of this "I think the O2 sensor is the problem" crap. /forums/images/graemlins/cool.gif /forums/images/graemlins/waytogo.gif
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: WinALDL
    I built the cable with local parts from Fry's, but Radio Shack or any electronics store should do fine. I added the "optional" stuff too since I wanted a cable that would work on any ECM, and some require the "trigger", though my truggy does not.
    As for what it all means, get a book called "How to tune and modify Chevrolet Fuel Injection" by Ben Watson ( ISBN 0-7603-0422-X ). That was recommended to me when I started fooling with the TBI in my truggy, and it will answer all your questions...
  3. heavy4x4
    Aug 28, 2002
    3,270
    Re: WinALDL
    Thanks for the book suggestion. I'll check that out. Those are the only kind of books I care to read. /forums/images/graemlins/eek.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif
  4. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Re: WinALDL
    Buy 2 or 3 of everything. I decided I was going to build the cable tonight so I went to radio shack and got the stuff, I just tried to build a cable 30 min ago. I snapped the center leg off the transistor when I went to take it out to the truck, so I went back inside and pillaged the kids 200-in-1 learning lab for a new one. Well long story short if you try to resolder /forums/images/graemlins/weld.gif a serial plug the odds of you melting the plastic and knocking the pins out of whack are pretty good. So tommorow I'm off to RadioShack again.
    I think I'm going to try the solder-less serial plug, or at least get the small vice things with aligator clips to hold the crap while I work. Oh yea I left my glasses at work which didn't help much (funny how after 35 years youfind out you need glasses then when they give them to you, you cant see anymore /forums/images/graemlins/histerical.gif)
    Oh yea total price for round one: 12.95 and that included some wire and solder (both of which I found in the toolbox when I got the iron out) /forums/images/graemlins/blush.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: WinALDL
    Any sites with explanations on how to make the cable?
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
  7. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Re: WinALDL
    customefis.com sells the cable for like $35. /forums/images/graemlins/dunno.gif
    -Dan
  8. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Re: WinALDL
    I bought all my parts at Radio Shack ~$6.00 for everthing. After I tested it once I filled the serial plug with hot glue to keep all the parts safe. I have a 1991 k5 and had to use the 12v to trigger aldl mode, but everything else was just like the website shows.
    I finally ran wires from the aldl connector and put a socket in the plastic cowl around the four-wheel-drive shift lever. Maybe I'll take a few pictures if you want to see.
  9. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Re: WinALDL
    Can you do any sort of programming with OBD1 and this program?
  10. dyeager535
    26,982
    191
    Re: WinALDL
    WinALDL doesn't allow you to actually make changes. You HAVE to get into PROM burning to do this, and WinALDL doesn't do this.
    WinALDL basically lets you see what the system is doing. It's an analytical program.
  11. heavy4x4
    Aug 28, 2002
    3,270
    Re: WinALDL
    Sure, if you could snap some pictures that would be great. I can kind of picture what you did with the cowl thing, but I'd still like to see it.
    So, for the wire, you included everthing that the diagram shows (all the resistors and whatnot)?
  12. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Re: WinALDL
    I finaly got everything done last night and drug it out to the truck at midnight....You know that little plug on the lap-top...its a monitor plug /forums/images/graemlins/blush.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/ignore.gif I was so pissed at myself the wife quietly snuk inside and went to bet without a word /forums/images/graemlins/rotfl.gif
    Any how I borrowed the IT laptop from work so I can play this weekend. If everything works OK I might get the USB/Serial cable and try it with my laptop.
    Oh yea when I looked at the 93 Suburban the E pin was empty on the ALDL plug /forums/images/graemlins/thinking.gif along with about half the holes. On one website I read about the M pin (which is under the A)...can I use this one or will it screw somthing up?
  13. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Re: WinALDL
    Here you go. I put a little 5 pin din connector on my cable and a socket in the plastic piece.
    I used everything this schematic shows except R3 and R4.
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: WinALDL
    Very nice idea. I might just branch off my cable to do that. But I want the raw leads so I can use it on any ALDL. Or just get an extra plug with the raw leads hanging off it, yeah, that's better.
    I looked everywhere for a real plug, but I just could not find one anywhere. Anyone hava a source?
  15. heavy4x4
    Aug 28, 2002
    3,270
    Re: WinALDL
    Thanks, that's exactly what I wanted to know.
    /forums/images/graemlins/thinking.gif I like that idea of a plug-in rather than sticking raw wires into the aldl outlet. I take it you just tapped into the wires running to the aldl thing-a-magig?
  16. dyeager535
    26,982
    191
    Re: WinALDL
    I've been looking for the other end of the ALDL connector, no luck. Someone must make them, all the scanners have them, just have to find out who makes them for companies like autoxray, etc.
    I would imagine though, as popular as the ALDL cable is, that someone would have found a source already. Have you checked thirdgen.org forums for this?
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: WinALDL
    Nope, mostly just asking around and looking at electronics books. Never really got terribly motivated by it, but that's probably a good idea...
  18. heavy4x4
    Aug 28, 2002
    3,270
    Re: WinALDL.....UPDATE: new question
    New question:
    Without looking at the back of my laptop, I went out and bought the stuff I'd need to make the cable. Well, I got the stuff home and /forums/images/graemlins/yikes.gif...looks like it's not going to work. Crap!
    Here's the connection on the back of my laptop:
    And here's the connector I bought that the schematic calls for:
    The connector is the right size but there's the wrong number and configuration of pins? Any ideas?
    I think I may e-mail the site I linked above in my first post (if I even can) and ask the guy if there's a way to make mine work. /forums/images/graemlins/crazy.gif
  19. ncbloodhound
    ncbloodhound 1/2 ton status
    Aug 18, 2003
    400
    Indian Trail, NC
    That plug on the back of your computer is for a monitor. See the little square below it. Look for another plug. If you have a newer laptop, it may not have a serial plug. I have seen newer laptops without them.
  20. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/doah.gif DOH!
    Well, here's the whole back of my laptop:
