winALDL ???
Discussion in 'The Injection Section' started by lamberthkp, Jun 23, 2006.
  1. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    ok i finally got a computer to run winaldl it is loging data and and when im done i went to the BLM and hit save, were does it save to and how do i e-mail this to tbichips? i opened it back up but i dont see any info on what was saved any help would be great thanks Keenan
    also i only have the cable pluged into port E under the dash if i plug the other pin in A it stops logging data i sent a msg to tbichips but nothing yet, anyone had there's do like this?
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    This is just a guess being I haven't run the program.. But maybe take a peek for a preferences or options tab.. Usually you can find where it's saving to, or change where it saves to in those....
    Plenty of peeps run it so you should have a definitive correction soon enough...
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
  4. snake383
    snake383 Registered Member
    Jun 23, 2006
    26
    Camp Lejeune NC
    that computer aint been nothin but trouble. get an older truck! just kiddin
  5. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    it should be saved in whichever directory the program is installed in. It will be a txt file.
  6. Creek
    Creek Registered Member
    Mar 17, 2006
    36
    Mint Hill, NC
    It will be in the Winaldl subdirectory (folder for you late bloomers) and the file name will be in the format of YYYYMMDD_HHMMSS_BLM.txt. An example would be 20060624_172331_BLM.txt. The hours are in 24 hour format. The date_time stamp is the instant that the file was saved. BTW, unless you specified differently, the Winaldl subdirectory is under program files. I use Excel to open them and do a little formatting for easier reading.
    David
  7. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    ok i will check that out im not the greatest at these kinda things, thanks :D
  8. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    ok found the files got it all sent off for a chip thanks for yalls help :D
