Winch: 3/8" cable or 5/16 Rope ?
Discussion in 'The Garage' started by 88Silverado, Aug 4, 2006.
3/8 Cable or 5/16 Rope
  1. 3/8 Cable
    5 vote(s)
    25.0%
  2. 5/16 Syn Rope
    11 vote(s)
    55.0%
  3. Who cares.....Im Naked..
    4 vote(s)
    20.0%
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Picking up a 8274 winch tomorrow. I'll probably re-cable it and was debating on going with either 3/8 cable or 5/16 Syn. Rope. The drum can carry 150' 5/16 cable but im also thinking about running 100-125 max and maybe carry an additional strap if longer lengths are needed.
    I know the advantages of Syn rope for snapping but I dont think the 8274 is capable of snapping 3/8 cable. Price is the main difference between them.
    Suggestions
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I think you already answered your question. The drum holds 150' 5/16 cable.
  3. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    where is the 3/8" synthetic option? :confused:
    j
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Anyone know how much 3/8 cable it would take to fill the drum? I've been thinking of going this route. The 5/16 has a break rating of 9,800 pounds, while the winch is rated at 8,000. I just installed a stronger motor, but I'm not sure how that will affect the winch's load capacity. There's not of buffer room on the winch load wise anyway, and I think I may have dropped the buffer even more with the addition of the new motor.
  5. 88Silverado
    Mar 13, 2003
    2,664
    Yea, I may have answered my own question but I wonder if anyone has actually broke 3/8 cable during use.
    5/16 standard cable says breaking point ~9K although im sure this has been de-rated some which is why its used.
    5/16 Rope is around 14K, which is around 3/8 Cable break point. Im thinking 5/16 rope is a good swap but $$$ wise, its about 2-3X more than 3/8 cable. (Unless someone knows where to get a good deal :wink1: )
    125' of 3/8 will fit on the drum as opposed to 150' of 5/16. I was concerned with short pulls and loosing performance having so much cable on the drum thats why I was thinking about 100-125' max with a separate extension if needed. The max pull of the winch is rated with a single turn on the drum and degrades with each additional layer.
    Cant see the benefit of going to 3/8" rope unless the 5/16 degrades that fast and from what I have read, it doesnt.
    OK, was looking for opinions. I figure cable or rope could be used safely. Guess the advantage of the rope then is its lighter weight and ease of use.
    Tnx!
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I run 3/8 synthetic cable on mine. That is what I would vote for. Remember that the strength ratings are for a rope in perfect condition. If there is a nick or fray in the rope it will decrease its load capacity significantly. Also, if you use a snatch block to double the line back to the vehicle, your 8000 pound winch (the 8274 is underrated at 8K) can now pull 16000. All you lose is 25 feet of rope and maybe $10-20 (3/8 is a little more expensive).
  7. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    rope, it is a lot easier to work with and lighter, too. Then there is the "stored energy" deal. With the 8274 you don't have any heat issues (ropes only neg).
  8. 88Silverado
    Mar 13, 2003
    2,664
    OK Thanks. Guess I should have put in the 3/8 syn option.
    I'll look around and see whats available. Ive read alot about AmSteel but dont know much about the others. Any suggestions on different manufacturers or where to buy ??
  9. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Well you all have about convinced me that synthetic is the way to go. Man that stuff sure is expensive!
  10. 88Silverado
    Mar 13, 2003
    2,664
    Yea. no kidding. Thats why I was looking at the 3/8 wire instead.
    The 5/16 rope is almost within my reach.
    Guess the price difference is what you gain in ease of use and safety.
  11. 1977k5
    May 26, 2003
    9,992
    130
    You said it.
  12. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    It's true that the winch can pull 16000 lbs. with the pulley configuration, but the rope only sees an 8000 lb force. That said, I still would go with 3/8" rope.
  13. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    It is over-rated
    Ive been told single line pull on the 8274 is closer to 16000lbs, thats how under-rated they are.
  14. Dallin
    Feb 12, 2003
    135
    I doubt it is that under rated, but maybe. My point is the rope never sees more force than the winch can pull. Using pulleys can double the force applied to an object, but that doesn't double the tension in the rope.
  15. 1977k5
    May 26, 2003
    9,992
    130
    Yeah, you're right. I don't know what I was thinking.
  16. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    synth rope is a wear item... thats why lots of hardcore guys use the 3/8" stuff.. it will last longer. Even if you don't fray it on rocks, gritty dust/dirt will get on/in the rope and start tiny little frays. 5/16" is plenty strong, it just won't last as long once you start degrading its strength which is pretty much inevitable if you actually use your truck.
    j
  17. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I didnt see 7/16 cable.. that is what I got... but on a diff winch.. :wink1:
    Patriot 15k here... dont think they make rope big enough for my winch so I chose the I'm nedded option :haha:
  18. 88Silverado
    Mar 13, 2003
    2,664
    Thanks guys, Lots of good opinions. Now if I can only find a bumper or figure a way to mount this thing on the Blazer i'll be set :doah:
  19. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    They make the syn rope for marine winches that will dwarf your "little" 15k lb Ramsey. You're just shopping the wrong place.:D
  20. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    yeah, you can get Amsteel Blue in all kinds of sizes. IIRC, it comes in 3"+ sizes and has an avg strength over 100,000,000 pounds in them bigger sizes. Oughta be enough for your cute lil winch. ;)
    j
