Winch/Battery Disconnects
Discussion in 'The Garage' started by DPI, Apr 30, 2002.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I am needing a switch to disconnect my winch so it is not connected directly to the battery. I am considering <a target="_blank" href=http://www.jcwhitney.com/item.jhtml?ITEMID=4431&amp;BQ=>this switch</a> for both my battery and winch unless there is a better way to do it. Any suggestions would be appreciated.
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    looks good to me
  3. greatwhitenorth
    greatwhitenorth 1/2 ton status
    Mar 10, 2002
    102
    Surrey, BC
    those welding cable conectors would work great.
  4. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    They have those at our local checker auto parts store. Why do you want to disconnect the winch? I use the stinger cable disconnects on my portable winch. You can get them from any local car audio shop or I can get you some from my shop if you are looking for a way to "move" the winch from place to place.
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    I am wanting to disconnect from the battery due to someone having the ability to short the connections at the winch. This can activate the winch and burn it up.
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    People do that? Wow, so what they cut the cables and touch them together burning up the winch? sounds like a rare case of vandalizum?
    to add to you search go here <a target="_blank" href=http://www.wranglernw.com/>http://www.wranglernw.com/</a>
    they have a ton of electrical parts and pieces.....
    good luck
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    You do not have to cut the battery cables. Cutting the cables would disconnect the power anyway. You can stick a metal object into the remote connection that will short the posts. Oh, thanks for the link.
  8. Burt4x4
    6,854
    Ahhhh, I see. Leave it up to the scum of the earth to figure out a way to mess with our rigs!!/forums/images/icons/shocked.gif Now you have added one more thing to the list for me to worry about/forums/images/icons/crazy.gif.....
    Have you ever heard of someone doing this?
    Or is your mind just being proactive?/forums/images/icons/smile.gif
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    No, I have not personally seen this happen, but I have heard stories and can see how easy it would be. Just like shorting a silenoid on a starter.
    I may be on the paranoid side, but would rather be safe.
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Wow, that switch is pretty beefy! Most winches don't pull more than around 450 amps at full stall, so a switch that's rated at 1,000 amps should be able to handle it. /forums/images/icons/cool.gif Just make sure that the winch is not turned on when you are switching the power on or off. That could cause internal arcing in the switch, burning the contacts.
  11. Burt4x4
    6,854
    I'm with ya on the rather be safe thing! People will do anything to screw with other peoples stuff!
    good luck
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have heard of (but never seen) people spooling out the cable, running it over the roof, and attaching it to the bumper before they short out the winch!
  13. Burt4x4
    6,854
    Man!! I can only hope to catch the fawker so I can fill him full of led!!!!
    Now I'm gonna have to swing by the gun shop and get more 30-06 ammo/forums/images/icons/smile.gif
