winch bumper and 52s
Discussion in 'The Garage' started by Bhintz, Nov 30, 2004.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    try searching but nothing, so for everybody running 52 inch springs and a winch bumper what are you doing w/ the L-bracket that you move in front of the body mount, b/c the winch bumpers (or at least mine) is in the way and I cant move the bumper back at all,
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    That is just the trauma with the 52 swap. Hard to get the bumpers on if you keep the L bracket and weak if you don't keep it. I think I would keep the L bracket and try to fab up some other mounting for the bumper. Good luck.
  3. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    What about incorporating an "L" bracket replacement into the bumper mount. It would all bolt together just like you would be doing by moving it and you'd almost never take the bumper off anyway.
  4. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    That's what I'm doing, it'll make everything nice and solid.
  5. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i just cut the bumper mounting plate around the l braket and its great, of course the bumper is built by me so cutting it to work was easy
  6. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    Thor,
    Is that a valve spring your using in place of the lower body mount bushings?
  7. lifethroughdeath
    Jan 26, 2003
    300
    New Bedford, MA
    I thought so. I remember a while back there was a post about using valve springs instead of body mounts, to allow some movement when all flexed up. It's all good
    Sorry for the hijack, I'd say make the bracket like mentioned above
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    In my opinion I wouldn't want the suspension bolted to the bumper. Seems if you banged the front bumper hard your transmitting alot of that shock into the suspension and if the bumper moves so does your axle and suspension. To each his own.
