winch cable ? updated with more info.
Discussion in 'The Garage' started by sweetk30, Jan 20, 2006.
top or bottom feed of the cable?
Poll closed Jan 25, 2006.
  1. top wind
    2 vote(s)
    8.3%
  2. bottom wind
    12 vote(s)
    50.0%
  3. I AM HEMAN AND DONT NEED WINCH.
    10 vote(s)
    41.7%
Multiple votes are allowed.
  1. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    how do you wind your cable to the drum?
    more info added: my unit is a ramsey 6000 lbs winch for my trailer. this is the one i would like the info on. thanks to all.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    There is only one way to wind it on correctly. Mywarn winch is wound from the bottom, if you try to wind it from the top it won't come out of the fairlead in the correct position. Most winches i've seen have a direction arrow right on the main body telling which way to wind cable on.
  3. sweetk30
    Nov 1, 2004
    25,537
    536
    in the big ones like on tow trucks thay can be run top or bottom. but the winch has to be set up for top or bottom feed. . :dunno: :1zhelp:
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    My Ramsey, and a few others I've looked at, specifically say to feed the cable in from the bottom. Not 100% sure why but this were all base mount style winches (mounting bolts were on the bottom) so if anything I would think having the cable on the bottom of the drum would put less leverage on it.
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Don't wind it from the top. It will rip the feet off or strip the mounting bolts. That is a LOT of extra leverage!!!
  6. sweetk30
    Nov 1, 2004
    25,537
    536
    this is how it is mounted now.
  7. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    My winch (warn 9500) said to mount with the feet down or to the front and wind the cable only from the bottom. I haven't had any experience with any others personally.
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    That is exactly what my warn XD9000 said.
