Winch-Gage of Power Cable??
Discussion in 'The Garage' started by IDGMC, Oct 12, 2006.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    So what is the min. gauge that I should run to my winch? I've got an old set of jumper cables around would they be a good candidate for power wires?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Probably not unless they are really good jumper cables (and then why cut them up?). I know my 8274 draws 450 amps at full load so I wouldn't mess with small wiring.
  3. IDGMC
    Feb 18, 2000
    150
    Idaho
    i've heard of using welding leads? I'm have a hard time finding anything heavy enough....where should I look for them?
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Any welding supply has the cable. I bought 1 gauge at our two NAPA stores. I wouldn't use less than 1 gauge.........:wink1:
    You can get a $20.00 crimping tool at NAPA as well, make them last and work better that way! Ask for heat shrink for 1 gauge as well to seal them from moisture/corrosion!
  5. IDGMC
    Feb 18, 2000
    150
    Idaho
    Do you remember what you paid per foot?
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Sorry, but no.........
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If you've got a marine hardware store local they're a good palce to look as well. If you know exactly what you want can try westmarine.com
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Yup, I much prefer tinned marine cable to welding cable, way more durable...
    Bigger is better... :D
  9. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,812
    396
    Clayton Del
    What do you mean by "tinned marine cable" ?
  10. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Tinned copper cable... Far superior corrosion and electrolysis resistence compared to welding cable...
