Winch idea
Discussion in 'The Garage' started by DieselDan, Jul 10, 2002.
  1. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    OK I've been thinking about this for some time. Electric winches are nice and fast but they can really tax an electrical system, on top of that many can't handle continuious duty mud requires (Do you rock boys understand "mire factor"?). Hydraulic have the power and the stamina but can be painfully slow. Then there's that engine not running argument.. PTO winches are a dying breed. When's the last time you saw a PTO shaft sneaking through a set of headers, over a high steer?
    How about powering a winch with it's own small 2 cycle engine! Robins (Subaru) engines in the 1HP - 2HP range would fit the bill. Light weight, self contained, should run at most any angle, if you're worried about deep water vent the aircleaner higher and start 'er up before you hit the surf.
    About the only problem to over come is constructing some form of reversing/clutching gearbox. Anything else I haven't thought of? Has anyone ever seen anything along these lines?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    hydraulic speed depends on the size of the pump.
    bigger pump = faster speed
    you could set one up to run much faster then you want/need
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    There is already a company selling a self contained winch as you just described. I don't remember who it was but I think it might have been Ramsey.
  4. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Yep, I know you could simple install a real hydraulic pump to power the winch, but you still run into that old argument about overturned or dead vehicles needing self recovery..
    I'll have to see that Ramsey unit. I would have thought somebody would have done this before. I wonder why it isn't more popular?
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Buy a Chainsaw Winch.
  6. greatwhitenorth
    greatwhitenorth 1/2 ton status
    Mar 10, 2002
    102
    Surrey, BC
    I believe some of the problems you would run into would be:
    (i know you already stated a couple here but for the sake of discussion)
    What sort of clutch??? Centrifugal?? hand levers like the old days???
    Gear train?? Most electric winches are about 4+ Horsepower and have a reduction ratio of about 150:1.
    I know what really matters on line pull is torque, but I have no idea what sorta torque a winch motor puts out.. lets say 24ft-lbs based on a 10000lb pull, 8"dia drum, 150:1 reduction.
    Faster winches will need more torque and less reduction to achieve the same line pull.
    Wouldn't be able to power out, no brake other than compression IF you get some sort of gear train with a reverse gear in it.. this may not be a problem if all you do is mud, but if you ever use the winch on an incline you'll run into problems.
    Size - a suitable 2 stroke motor will be pretty bulky compared to the size of an electric motor.
    I have thought about home made winches before, and read lots of posts like this and the best idea I've heard of so far is using a small 2-stroke motor to power a hydraulic pump for a hydraulic winch. with this setup you could mount the motor and pump in the bed or someplace outta the way and just run your hoses up to your winch.
    I have no idea what you could get a reversable drive train from, maybe a snowmobile w/ reverse... can't think of anything else reasonable small that would have a reverse gear.. tranny outta a vw or something.. either way its not gonna be very small.. Anyone now of small reversing drivetrain??
    This is a good topic, I'd like to learn more about this..
    Hope my stupid ramblings will bring someone with some firsthand knowledge into this post.
  7. ratpack7
    ratpack7 Guest
    Your right some one does make it. I'll have to find it it's a whinch that is hooked to like a chain saw. I think I saw it in a Cabellas catolog.
  8. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Wow 4+ horse from an electric winch? Are you sure about that? A 1HP 110Volt motor is pretty damn big (yes, it IS continous duty).
    Ya, you could simply power a hydraulic set up. Sounds alittle expensive, but workable.
    I was thinking more like a panetary set up, actuated by solenoids. 'Never seen that "chainsaw" winch.
  9. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The nice thing about an electric is that its quiet. It might be annoying to have to listen to a chain saw motor every time you winch.
  10. greatwhitenorth
    Mar 10, 2002
    102
    Surrey, BC
    Diesel dan, yes those are 4+ hp motors. dirrect current, and non continuous.
    I work at a mill so I am well aware of how big even a 1/2Hp continuous duty motor is..
