Winch Inna Bumper? Want one...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by uglytruk, Jun 22, 2006.
  1. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    Saw this on eBay...[​IMG]
    Item number: 220000382274
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    How would a person engege/release the hub?
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    That is not a warn winch. That is a Ramsey RE12000 worm drive winch.
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Winch might be mounted upside down with the lever pointing to the ground. Have seen several people do it before.
  5. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    You can also rotate the handle housing on most warns to change the location.
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Check out the picture. That is a Ramsey hidden mount kit with an RE series winch. There is no mistaking it. The motor and worm gear are visible.
    The warn M12000 has the motor inline and its a planetary winch...
    Check out this discussion - http://coloradok5.com/forums/showthread.php?t=176926
  7. uglytruk
    Oct 24, 2004
    1,329
    Luv youz guyz!
    Now I gotta' start looking for an affordable/used one, or two. Mebey one for the back also!!!
