Winch Location
Discussion in 'The Garage' started by DwarF, Apr 2, 2004.
  1. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    On the k5, it looks like there is enough room between the front frame rails to put the winch low, and inside the frame rails. Then the bumper can cost you very little approach. Has anyone seen a winch mounted inside the front clip like this? Under the core support, between the frame rails?
  2. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    Peterson's is doing a thing on an M1008 they got. This month's article shows a winch mounted that way under and behind the stock bumper...almost completely hidden.
    Red Blazer on the cover.
    Rene
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    How long goes it say for the retailer to display for? I went to get the May issue and they didn't have it yet. grrr...
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    DP_90K5.
    He's done this with his winch/K5.
  5. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I was told that you should put a cross member in the front of the frame and box the front of the frame as well on the Blazers. Any truth to this or is it overkill?
  6. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    MY winch is really hidden. It's mounted in a box in some warehouse! /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  7. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Mine Too!!! /forums/images/graemlins/doah.gif
  8. heavy4x4
    Aug 28, 2002
    3,270
    It's not a bad idea. GM straight-axle trucks are plagued with cracked frames at the steering box. These cracks are the result of frame flex, so anything you can do to limit the amount the frame flexes up near the steering box will help out. The most common fixes are a weld-in reinforcement plate and a bracket which triangulates the frame...both available from www.offroaddesign.com
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    mine is under the bed between the frame rails
    the remote plug is in the ps bed pillar inside the box facing forward
    I wired the remote by pulling the taillight
    the remote reaches through the sliding window for 1 man operation
    keeps weight as far rearward as possible
    thick plate bulkhead welded between framerails
    I am moving the solenoid pak to a more accessable location though as the framerail is a PITA to get to when you have problems with it
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  11. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Are you running front and rear or just rear? WHat type? Who have they been?
  12. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    DP_90K5 should be boxing mine up along with front/rear bumpers plus sliders and shipping them to me. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif Like a little kid waiting for Christmas to come.
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    just rear
    my truck feels way to front heavy to add anything up there
    it is an old winch made by Beaver
    dedicated deep cycle feeding it with good cabling
    I may move the battery back beside the winch or I may convert it to hydraulic
  14. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Uh oh! Here come the beaver oil jokes! /forums/images/graemlins/wink.gif
  15. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    That's only if he converts to hydraulic
  16. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    well, mine is not under the core support, but is set way back to not loose anymore approach angle than absolutly necessary...
  17. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Have any cooling problems with that?
  18. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Not at all, I am running a dual speed electric fan out of a Taurus w/ a 3.8
    The only time I have any cooling problems is when I forget to turn it on!!
  19. rvreddog
    rvreddog Registered Member
    Oct 14, 2002
    67
    San Antonio Texas
    I mounted mine like that after banging it on the rocks a few times. Right now the winch is flush with the grill,but I`m gonna move it back so the roller is flush. A word of warning,when you do this clock the switch (lever) on your winch. It`s a tight clearance in there and a new housing end will cost around 75.00. The voice of experiance.
  20. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Plenty of room down between the rails. Here's a pic of Stomper's new front. This one has an RE12000 mounted between the rails. I also fabbed one that mounts a Patriot 15000 between the rails.
    Here's a couple looks at the mount for the RE12000.
