Winch mounting
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by MNorby, Mar 18, 2007.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    Scored a REP 8000 winch so playing with its mounting. Clears the rad support by about a 1/4". The 12,5 t-max will require notching of the rad support though when I get one. Then this one will turn into a multi mount setup for the rear, tow rig, trailer.
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Just be sure to mount it per the manufacturers instructions......
    Unlike my buddy Nate (barbastard) in this video
    http://www.youtube.com/watch?v=sNg1jLUjhmc
    He sheared every mounting bolt. Should have mounted it with the feet facing forward instead of down, those 15K winches create a lot of force!!! :yikes:
  3. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    according to the ramsey website it says to mount feet down and that is also how it was mounted on the trailer I got it off of.
  4. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    So does my Warn 9.5K.
    I looked into/wanted to mount it feet forward but figured I best follow the destruction's. :dunno:
  5. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    I have my M8000 mounted feet fwd, not a problem. On the warns, you take out all of the screws that hold the gear selector plate and gently lift up about 1/4" rotate to desired position and reinstall the bolts. Mine has been this was for 4 years now without incident.
  6. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    :eek1: :eek1: :eek1:
    Damn!
    In 30 years of offroading I have never seen something like that. I have also never seen anyone mount a winch any other way but feet down.
  7. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    from what I understand most with built in selinoids (technical name escapes me right no) are feet down and most with a seperate box are feet forward but the ramsey website shows this one feet down and the one I will get to replace it (t-max 12,5) are both feet down and same 10x4.5" mounting so should basically be a bolt on swap, except having to trim the rad support for that bigger winch.
  8. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    I'm going back and forth aboot getting a 9000lb. removable winch.
    What do you think?
  9. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    removeable are nice, 2 friends run 12,5s on multi mounts (serious, serious mounts, winch and mount weighs 189 lbs) and they have receivers in the front and in the bed. My thought is on a trail I want to make forward progress and having it on a receiver in the front kills approach angle. When I get my 12,5 winch I'll make this into a multi though for rear use, trailer, use, etc because it is handy
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Greg, who was the laughing chick in the video?
    Got any pics of her to put in the Pig Pen? :D
  11. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    did it just shear the bolts or break any of the housing? A frined m8000 broke a leg off. It was mounted correctly but the cable got wound up on one side and pushed it away from the mount along with bent the tubes that hold the 2 winch halves together. I built him a collar that went around that side and had a mounting foot and is still working today.
  12. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    That is RedChevyGirl on the NorCal site.....
    Don't think she's the type for doing PigPen photos but I'll let you ask her directly.
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Never hurts to ask. Afterall, you never know what you can get by doing so.
  14. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    :doah: :haha: :doah: :haha:
