Winch on Trailer *DONE*
Discussion in 'The Garage' started by perp, Sep 3, 2005.
  1. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    Hey guys, I am going to mount a winch on my trailer today. Its a 8000lb ramsey (older wormdrive). I am putting it on the front of the trailer because i know eventually I will need to load my truck after breaking something off road, and the ramps are way to steep for pushing it up. my question is that I bought this winch as you see it for $100 a few years ago out of a impound yard. it was laying underneath a truck (probably hidden by a previous employee). I want to mount it in front of the trailer jack and off slightly to the passenger side so the line will miss the jack. what kind of support does a winch need. i realize the obvious strength of the mount (MIN 3x the pull force) but i haven't seen one of these mounted in the past on anything so i jut want to make sure i support all the neccesary areas. Tell me if I am wrong but i think you need steel front and back so the clutch and drum do not try to walk away from the gearring? looks like the frt/Rr mounts bolts actually hold the parts together? I did search and found mostly pics of bumpers but no real details on the actuall mount points. any suggestions or input would be appreciated.
  2. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Do you have a model number on the winch? In the past I have found it easier for me to get a mount from ebay and make it work. Heck if you can find a mount for a heep it will just near bolt onto a trailer. Most jeep mounts are simple "L" style brackets since the 2 frame rails just protrude out. I got one last week for an 8274 for 25.00 then used two stub pieces of I beam to mount it to the trailer. The nice thing about that I do not have to drill the mounting holes for the winch in the plate... ;)
    {hijack on} What model number is that PJ trailer and what is the deck width and height. Is it a bumper pull or pintle hook? Thanks {hijack off}
  3. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    thats a good idea, I will look into the heep mounting idea. as for the trailer I will go look and get back with you in a few, but i know the deck is 96" outside to outside measured to the outer edge of the rub rails.
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    didn't see the last part of the question. It was a 2-5/16 ball bumper and i changed it to a pintle eye
  5. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    heres a picture of what i mean by changed from ball to pintle. was real easy, only draw back is the ball coupler (top) is rated for 14,000# and the pintle eye is 12,000#! go figure. I use it in my business to haul tile and i run it behind several trucks, one of which only has a pintle hook, thats why i swapped it. this has been an excellent trailer and i would buy another one no problem.
    It is a little heavy, but the 2500HD chevy with a 6.0 & 4.10s hauls it all day long, and the CTD its on in the picture doesn't even realize its back there.
    hope this answers your questions,if not ask away
    Specs:
    18' long (deck)
    8' wide
    32" deck height
    15,680# GVW
    3,850# empty
    6' HD ramps stored in ass of trailer
    model # DE182 (from sticker on tounge)
    I paid $3400.00 before tax
  6. dremu
    Feb 27, 2000
    15,952
    443
    East of San Francisco
    Oooh!
    That there is a Ramsey model 2000 or 2001 or thereabouts ... they make GREAT hidden winches for our trucks ... might wanna hang onto it.
    I have one behind my bumper ... I can provide plans for the mounts to put it 'tween the frame rails. It's just angle iron and some flat stock. And a LOT of hardware :haha:
    -- A
  7. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    2 problems with your style winch. 1 is motor section on bottom. will make it so it needs to be up a bit , but o.k. for trailer use. 2 is you need to mount the winch dead center for the cable to spool up on drum corectly. or it will ball up on the one side. good luck. this is how i mounted my ramsey re6000 .
  8. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I finally got around to mounting this thing and taking a few pics, i ended up cutting a hole in the deck for the motor and the square tube that ties it to the frame. the channel is C5x about 6 or so , i got it used so i am not sure on the weight but is beefy, and the tube is 3/16x2x2. now i need to make a battery box and figure out the charger wiring so it doesn't fight with my Break Away battery.
  9. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    looks nice. Nice tow vehicle!!! (I love my Dodge too!)
  10. sweetk30
    Nov 1, 2004
    25,526
    526
    i went to local welding supply house and got 30' of 2/0 cable. ran it on frame to batt and back bumper. then whent to local fork truck shop and got 2 replacement ends for batt quick conect and the covers for when not in use. this gets me full power to winch from running truck and is just plug in and use it.
    try this for parts to di what i did. www.awdirect.com and then part#sm-50 quanity 2, and sm-7b quanity 1. this with the cable is basicly all you need other than some zip ties to secure it and a big terminal end to conect to the batt .
  11. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    Sweet K30 - thanks for the tips and the cool web site link (in my favorites now). round about what did the cables cost you?
    MXfireman - Is your Dodge a Diesel, if so have you done any performance mods to it? i am thinking about a chip/exhaust etc and am looking for advice from others as to what is real and what is hype
  12. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    Nope got the Hemi couldn't justify the diesel to the wife since she was the co-signer, I really wanted it though. A few guys out here are running the six gun and are raving about it. He also has the 4" exhaust. Have you been on towrig.com and looked into perfomance there for it?
  13. sweetk30
    Nov 1, 2004
    25,526
    526
    no problem with the link. and friends dad owns the shop so i got the special deal of the day on cable. if you have a tractor supply thay sell it in bulk.
    and my friend has a 04.5 cummins 600 series. he did lots of reading and best one every one likes is the edge. he got it and loves it the best unit. i can get the guys name he got it from at a smoking deal. he sells so many he geat discount buys and sells them cheeper to all of use.
  14. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I'll check out Towrig and if you could get me the name of that guy selling the parts cheap that would be cool
  15. sweetk30
    Nov 1, 2004
    25,526
    526
  16. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    thanks
