Winch operation (normal?)
Discussion in 'The Garage' started by Hossbaby50, Oct 13, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I was wondering if this is a normal thing for a winch. I have a Warn 12K that I bought used so I don't know if this is the way it is supposed to work.
    Whenever the winch has a heavy load on it (I would guess above 3000lbs or so) and is pulling in it pulls fine, but if I stop pulling the winch lets the cable back out until lets off some of the weight.
    I was pulling a treestump out with my K5 (heavy, 6000lb+ I would guess) I was winching in and my buddy was holding the brakes. The tree had enough root that the winch started to drag my truck up my driveway, so I stopped the pulling. During the pulling the winch loaded my front springs and pulled the nose of my truck down, and when the winch stopped the winch let out line until the springs had unloaded and the nose of my truck came back up.
    Is this normal? Thanks
    Harley
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    nope! Mine doesn't do that. Neither does Shawn's. I would call Warn. Sounds like something needs attention.
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    So it should hold all the weight until I let out right. That is what I was thinking, but wasn't sure. It pulls like a beast but it lets some of it back out if you let off the switch. Thanks Toby.
    Harley
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Sound like the brake is bad.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    That is what I was thinking but wasn't sure. I bought the winch used form a friend of mine for a really good price so I can't complain. I knew something would probably need a little work. Sounds like Warn is going to be needing to send some parts my way. It will probably have to wait though. I still haveto get my truck running. Thanks
    Harley
