Winch power requirements
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88k5canuck, Jan 14, 2002.
  1. 88k5canuck
    88k5canuck Registered Member
    Mar 1, 2001
    26
    Ontario, Canada
    I recently pickup a Warn M8000 winch. I am mounting it on a reciver winch plate so it can be run in the back & front. I am usually 2 gauge welding cables for the power cables off the battery. The truck has a stock replacement battery & stock alternator. I am I going to kill my battery & alternator the first trip out? I will probably be doing multiple pulls each time I go out. Should I upgrade to a dual battery setup, running them in parrel? And will the stock alternator be able to charge 2 batteries? Thanks for your help.
  2. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    I have the HS9500i and run stock alternator and red top Optima . I have had no problems.
    <a target="_blank" href=http://www.keith.rockcrawler.com>www.keith.rockcrawler.com</a>
