Winch Q's
Discussion in 'The Garage' started by mightywhitey_k5, Apr 11, 2005.
  1. mightywhitey_k5
    mightywhitey_k5 Registered Member
    Sep 3, 2004
    74
    how many Lb. winch should i need to pull my blazer out of any thing i might get stuck in. 12000 lb. waren is what i want but is it really what i need?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Rule of thumb is one and a half times the weight of your vehicle. I had a Warn HS9500i and it worked great! You should be good with a 9K# Or higher...
    One thing that concerned me was line speed. When you get into the cheaper winches and larger winches, the line speed is sometimes very slow.....
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    what type of terrain to you wheel in? in general terms, mud is going to put the most strain on a winch... nothing harder than trying to pull a rig buried to the frame in mud. For that kind of use, you'll want the biggest (highest # rating that is) winch you can afford. For not-so-muddy trail and/or rock use you could use a lighter winch and get away with it. Plenty of people use the warm 8274 of fullsize rigs, for example. Unless you do mud, I'd recomment something between that and the 9500# winches... oughta be enough.
    j
