Winch question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillR, May 27, 2000.
  1. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    I've been looking at winches and I'm wondering if an 8000lb Ramsey is enough for a K5. I heard that 1 1/2 times the weight of the truck would do it, and that's about the size of the winch's power. I also know about using a pulley as a doubler for the line. Let me know what you guys think...
    Blazin' in Flagstaff
  2. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    I have a friend that has an 8000 warn and he can and has pulled him self to hell and back. But I dont have one yet I wont to get a warn 9500ix and put it on a resiver mount.
    [​IMG]Go prepared
    </font color=red>90 k5 soon to be big, bad, and mean
  3. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    i'd recommend a 9000 or a 10000
    leave the 8000 for the jeeps
  4. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Keep this in mind. The winches are rated at the last wrap on the drum. What are you going to do if your only 20' away from your anchor point and quite stuck? Well your stuck. Call either my self or one of the others with a 95i or shawn and his 12000.
    Go big or you'll regret it...
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  5. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    actually I would use a warn the warrenty and help is great compared to what ive heard about ramsey .
  6. Corey-88K5
    720
    coopertwpk,
    You speak wisely o great one...
    The fact that Warn's customer service & the products were top quality was what set me on the warn track. I have no regrets and will continue to use warn on all my products.
    Corey
    88K5
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Actually, I'd use a snatch block in that situation.
    On another note, what do yall guys have against superwinch? I have an opportunity to pick up that line at work. They seem to be built well and their load ratings are more real than the competition. (working load instead of stall speed)
    Tell me all the war stories.
    Bryan
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  8. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Bill...my 79 sports a WARN 10K up front...no problems at all!!!
    AZBLAZER
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
  9. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    It sounds like everyone agrees that "more is better" in this situation. That is probably true, but hear me out. I read a story once about a guy with a Heep that thought "more is better" and he put something like a 9,000 lb winch on it. A few months later when he was trying to winch somebody out, he ended up pulling the frame apart. He said if he would've stuck with a smaller winch, it never would have damaged his truck. I doubt a 10k or 12k winch would damage a Blazer like this, but I'd steer clear of hooking up a 20k PTO winch just because it was huge.
    '73 K5
    Chevy good...Ford bad
  10. Corey-88K5
    720
    As far as Superwinch, I think they look like poor quality.
    As far as the guy who ripped his chassis apart. You should really only use your winch on either your self OR smaller vehicles. If you try and pull something larger than what your chassis can support ofcourse you are going to destroy your truck.
    Keep in mind, these chassis were never designed with a winch in mind. If they were, they would be factory options.
    GO BIG!!!
    COrey
    88K5
