Winch Saver product review?
Discussion in 'The Garage' started by Ned Kelly, Apr 12, 2007.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
  2. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    If your worried about it, then get one. I used to run a heavy wreacker, did it for a few years. I saw my share of cable breakage and improper attaching, and was always able to "back out of it" in time. so no I wouldn't get one.
    I once even had a 3/4 inch cable singing (the noise they make just before they break) submerged Bulldozers are really fockin heavy!
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I have one on my rear winch. Never finished wiring it up so I don't know how well it works.
  4. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    for the under $30 range how could you really go wrong
  5. runamok151
    runamok151 1 ton status Premium Member
    Oct 24, 2005
    12,557
    1,483
    the armpit of the east coast, 08046
    i have one on my winch. i like it. it lets you snug up the cable without having the hook attached to another part of the truck. i used to keep the hook on the side of the winch bumper. it scraped off the paint and started to rust. also the constant tension caused the winch bumper to look out of shape. i also like the idea that you always have something already in place to slide down the cable to absorb the shock of a cable snapping. i haven't broken a cable yet, so i don't know how well it would work compared to a sandbag. but weight is weight.
  6. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    thats what my wonder is, if the winch saver is at the winch, how does it absorb the energy if the cable breaks at the hook end.
  7. runamok151
    Oct 24, 2005
    12,557
    1,483
    its just a urethane donut you put on your winch cable. when you're winching you just slide it half way up the cable. then when you're done, just spool your cable back in until the hook snugs up against the urethane. always on the cable ready to use.
  8. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Get it. Better safe than sorry.
    Like said above, you put it about halfway to the other end of the line. If something should break, the weight will pull the snapped cable down. I also raise my hood when winching others, just in case.
  9. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Excellent....I'm on one.
