Winch setup with remote batteries?
Discussion in 'OffRoad Design' started by Sandman, Dec 11, 2002.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I was curious where you put your battery or batteries on the ORD Blazer and what kind of cable you used to connect your winch. Thanks.
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    They're behind the driver's seat. I took one out for the supercrawl but will probably go back to duals for trail rides. I'm using #2 welding cable if I remember right. Haven't had a problem with elec. power so far but I would like to have a bigger cable. I think I'm going to move the batteries back a little farther before next spring and I'll have to re-cable it so I might go a bit bigger. I figured the voltage drop with what I have now under hard winching conditions and my line size is marginal but with a high amp alternator on a real short lead to the winch it takes up some of the slack. The EFI motor also starts with minimal cranking so it doesn't take a lot to make it work.
  3. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks. I havnt decided quite yet where to put mine, but behind the seat is looking the best right now.
