Winch stuff? help
Discussion in 'The Garage' started by sled_dog, Oct 22, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    New to winches so what should I be looking for? Just want a winch on the K5.
  2. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    buy a used warn 8274, its the best winch ever.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You are looking for a winch that is rated to pull 1.5 times the weight of your truck (or better) with everything you take wheeling with you in it. Tools, people, gas, parts, spare tire, etc. In my opinion you should buy the most winch that you can afford, and buy a winch that is more then what you think you will need. If you think 8000lb is enough buy a 9K.
    I put a 12k Warn on my truck, but I got a sweet deal on mine so I couldn't pass it up. I think that a 9K or better is what a K5 should see unless you have lightened it alot. The only exception to this rule is the Warn 8274. It is rated at 8K but it should meet most offroad duties, except maybe extreme mud, and hardcore rocks with a heavy rig. It has 150ft. of cable so you can double line it very easily and have 16K pull power.
  4. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    I just bought my MileMarker 12000lb Electric from 4WPW for $599. Pretty inexpensive and has a lot of the nice features.
    -Andrew /forums/images/graemlins/usaflag.gif
  5. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    heres a few things to rember
    flat ground it will take a winch that has equal pull to your wieght
    if your axle deep in muck it incresses to 150% of pull to weight
    then if your frame deep you need 300% pull compared to weight.
    and up hill it all depends on the grade, but whith a winch that can pull 300% more than your truck wieghs you will be able to drag it up a cliff. That said for most off road stuff youll only need one whith that can pull your truck then half again, so a 9,000lbs winch should be good for the average trail fairing K-5, but i would definetly get a snatch black as well.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Me too, just recieved mine today.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] Sounds like thats my winch, with a snatch block and good recovery setup I should be good to go.
  8. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I like it when you are frame deep and going uphill.
    /forums/images/graemlins/cool.gif
    Ken H.
  9. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Hey I did as well. Mine will be here tomorrow. What si your impression of it?
    The only bad thign I have heard about it is that is has no braking when freespooling so it can rats nest.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If 55Willy would build my damn bumpers faster I could try it out. /forums/images/graemlins/smile.gif
  11. clubba68
    Dec 6, 2002
    1,511
    Good info, but your percentages are off. /forums/images/graemlins/deal.gif
  12. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I got mine hooked up today, works great as far as I can tell, sitting on the end of my truck and spooling in and out with no load.
    VRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR /forums/images/graemlins/laugh.gif
