Winch/Trailer q's
Discussion in 'The Garage' started by dheavychevy38, Feb 20, 2007.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Ok i am mounting my 9000lb winch on the front of my trailer what size cable do u reccomend i run from the truck to front of the trailer Thanks Denny
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Uh what?:confused:
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    What size cable should you run on the winch? It is spec'd for 5/16".
  4. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    He's asking what gage cable to run from the battery on the truck to the winch on the trailer, duh... :p:
  5. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Have you considered putting a battery on the trailer instead of trying to run everything off the rig? Usually trailer winches are only used for short pulls, so a fully charged battery has more then enough juice to do the job. If you still want extra power you can get away with running 8 ga wire from the truck battery to the trailer battery to keep it charged.
    Otherwise, if I'm doing the load equation properly it looks like 2ga for the 20+ foot run figuring the 300 amp draw. Problem is, I'm not sure there is a commercial connector that works with that large of wire - most of what I see is for the 4-8ga size stuff.
  6. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Never thought about the battery on the trailer idea thanks ya i was just wondering cause i will be doing this soon. Thanks Denny
