Winch wont work, bout to give up!
Discussion in 'The Garage' started by PRITCHETTK, Jan 16, 2006.
  1. PRITCHETTK
    PRITCHETTK Registered Member
    Jan 13, 2006
    16
    OKLAHOMA
    I just recently bought a used warn m8000 it worked when i plugged it in the first time now that I have it home it wont do anything. The connections are kinda rusty I cleaned them as good as I could, still nothing! I took the main motor wires and hooked them to the battery and all i get is sparks. I guess I will just take it in to the local alternator shop and hope he can fix it. I dont know what else to do, or how to check the silenoids. :mad:
  2. PRITCHETTK
    Jan 13, 2006
    16
    OKLAHOMA
    this really bites! noone to help me :(
  3. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Have you checked the continuity of the hand grip? have you checked the solenoids? dont pay some one to fix, do it your self. Some one on here has the schematics im sure.
  4. PRITCHETTK
    Jan 13, 2006
    16
    OKLAHOMA
    I will check for juice tommorrow, I dont have a voltage meter right now. Or a light tester.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Do not take it to a shop until you spend the $10 for these 2 items and do some basic trouble shooting as in continuity checks. Winch circuits are not that complex give it time someone will help out.
    Ira
  6. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    If you have a soldering gun, 1156 bulb and a piece of wire you can make your own test light with the addition of 9volt batt for continuity testing.
  7. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    Do you have the separate controlbox? If so you have to ground the controlbox for the winch to work. I had the same problem with my winch and thought it was broken too.
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    yeah I got my ramsey 15k patriot with wireless kit and thought the same thing.... until I grounded the control module.... (remote control winch... SAWEET :bow: )
  9. PRITCHETTK
    Jan 13, 2006
    16
    OKLAHOMA
    Well the control box is not grounded so that might just be it, I will try it out and hope so! nI dont even have the box bolted to anything soo. Thanks for the help everyone!
  10. Ramsey_Crawler
    Ramsey_Crawler Registered Member
    May 12, 2005
    38
    What part of Oklahoma are you in?
  11. PRITCHETTK
    Jan 13, 2006
    16
    OKLAHOMA
    I live in Salina, Oklahoma. ABout 45 minutes NE from Tulsa. Where are you at?
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Do the solenoids click when you hit the controller button? Are you sure the controller is plugged in correctly, and fully seated.
    I had a Ramsey that sat in the garage for years. After installing it everything worked fine the first couple of times using it, then the motor stopped turning intermittenly but you could hear the solenoids clicking. Also directly feeding the motor with the battery resulted in nothing. I disassembled the motor once, and not being overly familiar with electric motors, did not notice anything wrong. After more issues I took it apart and had an electrical guy take a look...he immediately noticed some build up on the motor brushes. I couple minutes with some fine emery cloth and a little electrical cleaner and it works like new.
  13. PRITCHETTK
    Jan 13, 2006
    16
    OKLAHOMA
    Well fixed the problem! It is the switch! Should have known.
