winches, wenches and witches
Discussion in 'The Garage' started by Mad-Dog, Jul 4, 2005.
  1. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    I have been kicking this around for a while and thinking that since a winch is designed to be used with a split sheave (2:1) pulley and MOST pulls only run far enough to clear a log or pull the wheels out of a hole......would it be more cost effective to buy a winch that is rated for the weight of the vehicle and use the pulley every time you had to undo yourself from the goo.
    I know it sounds crazy to me too since it be so much easier to have a winch that is rated for 2x the vehicle weight and run only 1 cable to a tree...... :doah:
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I see it as sort of parallel to the big engine - small engine debate. Both will do the work, but the big engine isn't working as hard as the small engine is.
  3. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    But...
    You may not always have a big enough tree, or if one is too far away, the motor on a smaller winch will get hot quicker and drain your battery reserve faster. :thinking:
