Winches
Discussion in 'The Garage' started by LAXandBLAZERS, Oct 31, 2002.
  1. LAXandBLAZERS
    LAXandBLAZERS 1/2 ton status
    Jun 2, 2002
    100
    Durham North Carolina
    Is a 8000 winch enough for my /forums/images/graemlins/k5.gif? Is was looking at the Ramsey 8000. would this be enough?
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no...9500 if you are 1 ton with only a small block, no top when you wheel and no tailgate.
    or that is what Bent & Twisted tells me /forums/images/graemlins/grin.gif
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    not really thats pushing it. i wouldn't go any smaller than a 9500 /forums/images/graemlins/grin.gif
  4. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    The only 8000# that you'd want is an 8274, cause those things are TOUGH as nails and will pull a house.
  5. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    If the choice is 8K or nothing I would rather have the 8K. If money is not the limiting factor buy something bigger like 10-12 K. I have a 9.5k on my K5, a 12K on my K30 and an 8K (warn 8274) on my Suburban. I've gotten UN-stuck a lot of times on a 4K hand winch /forums/images/graemlins/smile.gif
  6. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    If you are talking about the RE series in the Ramsey 8000, then that would probably be enough IMO. Those are the worm gear drive, they have a slower line speed but can pull almost anything out of a bad situation /forums/images/graemlins/thumb.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  7. LAXandBLAZERS
    Jun 2, 2002
    100
    Im lookin at the REP 8000 /forums/images/graemlins/k5.gif
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I seem to get by with my Warn 8000I. I would like something with a little bit better grunt though. It got a lot better when I went to a dual battery setup however.
  9. Grim-Reaper
    7,385
    Atlanta
    8000 will work. You can always doubline and get 16,000 out of it.
    Personnaly for wheeling I really feel that line speed is important. I have been in a situation where I would have rolled if it had not been for the 8274 that was pulling me. I run a HS9500i. Not as fast as a 8274 but it's close.
  10. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    i have a Warn 8000i that i picked up for $250 with a Roller, it has worked for me. But i have just used it when i was on an incline that i just did not want to push my 10 bolts with no lockers.
  11. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    i have two bats as well, how do you have your set up wired? i was thinking about running a switched cable from one + to the other + for times that i run my winch or when i have to jump start myself.
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i have a viking winch. its an old industrial winch. its only 8000 lb, but it has always worked for me. it has about 250 feet of 3/8 cable. its electric worm gear driven. pulls 9:1 i think it says.jjust get you a block and double it. keep in mind all mine is in mud and not up mountains like a lot of these people. mine will pick the blazer up in a tree though.
    my .02
    nathan
  13. LAXandBLAZERS
    Jun 2, 2002
    100
    yeah all we do around here is mud also. Whats the best place to buy one? /forums/images/graemlins/1zhelp.gif
  14. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Depends on the wheeling you do also. Rocks require less than mud. Mud creates A LOT of suction. I would hold off on the 8k myself.
    Ken H.
  15. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I run my alternator strait to a Battery isolator and then run the two wires to each battery. The second battery goes to stuff like radio, aux fan and stuff. I then ran a ford selenoid with some battery cables. If I need to jump myself, or need the extra power for whatever, I hit the switch. Seems to work out OK.
