wind wing busted!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KGBLAZER83, Mar 2, 2000.
  1. KGBLAZER83
    KGBLAZER83 Registered Member
    16
    sanat barbara california
    my driver side wind wing handle took a dump it looks like there is a little pin on the underside that is missing now the handle just flops around and water and wind just pour in. can i get a new ahndle or fix this one.COLD AND WET IN CALI. i have an 83 silverado
    blaze on!!!!!
  2. Captkaos
    Captkaos 1/2 ton status
    198
    Birmingham, AL
    You can still get this from GM. Bought 2 (drivers and passengers side) for mine last November. Want the part numbers?
    Chris Lucas
    http://www.wwisp.com/~captkaos
  3. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    Do you have them? I am interested in them if you do. My drivers side also went bad. Thanks
  4. Captkaos
    198
    Birmingham, AL
  5. Captkaos
    198
    Birmingham, AL
    Handle kit PN#
    LH Handle kit PN# 15617125
    RH Handle kit PN# 15617124 or 26, couldn't find this one in the pile of stuff yet!
    Chris Lucas
  6. UT77GMC4x4
    UT77GMC4x4 Registered Member
    Feb 24, 2000
    15
    UT--Salt Lake City
    Re: Handle kit PN#
    You can get the whole assembly (wing window, window channel and weatherstrip) for $150 per side at the dealer. Good luck.
  7. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    Re: Handle kit PN#
    You could probably get the whole assembly at a junkyard for $25-40 dollars.My window pivot on the vent frame broke and I was able to get the whole assembly free from a junk truck in a guys field. The handles were different depending on the year so be careful if you want yours to match.
    Blazerbob<font color=blue>[​IMG]
